Home > Maintenance & Mods (L322) > Clapping noise from front brakes |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Have you got discs like this.....
21st Jan 2017 12:21am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Hi might - brand new genuine rr discs from Dan at duckworths 2 months ago - shouldn't be cracked should they? |
21st Jan 2017 9:56pm |
Could be the pads moving in the calliper, or if the calliper sliders are worn then them moving a bit and letting the calliper move against its carrier.
21st Jan 2017 10:28pm |
I would check to see if all the calliper bolts are tight. |
22nd Jan 2017 12:01pm |
StewD Member Since: 22 Apr 2016 Location: Glasgow Posts: 129 |
Or the carrier bracket that the calliper is attached to... two big bolts at the back of the brake assembly. They would have to have been removed to replace the discs and might not be fully torqued up 👍 Current: Supercharged 06 FFRR in Java Black
22nd Jan 2017 2:41pm |
