Home > Maintenance & Mods (L322) > Amount of oil needed for a change on a 4.4TDV8 2011 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
23rd Jan 2017 1:14pm |
Ginge Member Since: 19 Apr 2016 Location: Tamworth, Staffs. Posts: 22 |
thanks for that,
23rd Jan 2017 1:45pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 761 |
9.5 litres is what you need
23rd Jan 2017 2:02pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
If doing vacuum extraction and filter replacement you will need 9 liters .I change oil every 5.5~6 T km. and every other time I drain secondary drain bolt, hidden bay the cross member of a sub frame and there came out about 1/2 liter of oil, so with that you will need 9.5 l of oil.It is important to chek level when oil is hot. When cold level should be in the middle. Here is picture of my homemade PVC drain pipe and old fridge compress, work like charm.
23rd Jan 2017 9:45pm |
I hadn't thought about sucking the oil out. ill leave that up to the mechanic though. Im sure he will find a sump plug or he will have to take his fridge apart too!
24th Jan 2017 1:07am |
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 |
you are not telling us (showing us in fact) that you "rise" the 3 tonnes of FFRR on wooden blocks?
24th Jan 2017 9:10am |
Dear heppsen, if you take closer look you will see that there are 5 supports an the 4 metar long ramp, and I used 3 5x12cm beams. quite sturdy and static engineer approved. Are you a static engineer? |
24th Jan 2017 10:31pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
Nice one Like the half-time refreshment on the plank. 405 AB exec seats Baltic and Cirrus
24th Jan 2017 10:56pm |
unfortunate it is 0% but benefit is you can have it in the car.
24th Jan 2017 11:20pm |
so...
28th Jan 2017 2:08pm |
First one
28th Jan 2017 2:31pm |
Thanks for your help all,
28th Jan 2017 3:54pm |
