Home > Maintenance & Mods (L322) > Driver window issues from cold snap?? |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Could the window frozen in the guides?
24th Jan 2017 9:23pm |
jz Member Since: 31 Mar 2016 Location: London Posts: 55 |
thanks for coming back - checked and all good as were all other windows, thought this a precursor to window motor on its way out brought on by cold snap - anyone experienced same issue of late? |
24th Jan 2017 11:52pm |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
Yes, I had one instance a couple of weeks back. Cold morning (-5c) and tried to lower the drivers window and it wouldn't budge at all due to being iced up. The following day I used the car around midday and the temp was (+5c) and when trying to open the window it lowered about 1cm and then got stuck. Tried several times, but same result. After parking up for a while to get some shopping I got back in the car and tried again and it worked fine and it has be OK since. Weird! But that's Rangies for you SDV8 AB MY 2019
25th Jan 2017 10:36am |
getting that impression - appreciate comments. |
25th Jan 2017 2:27pm |
