Home > In Car Electronics (L322) > Battery drain issue after fitting tracker |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
Fitted tracker recently which works great.
25th Jan 2017 3:13pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34912 |
would the tracker somehow be keeping the westie awake.... |
25th Jan 2017 3:41pm |
Hadn't thought of that. How can I tell?
25th Jan 2017 3:45pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Just try running a wire direct to the battery, could even go outside to get it there for now, see how that works... Pete
25th Jan 2017 5:12pm |
Thanks Pete
25th Jan 2017 5:17pm |
Yes to both mate... Pete
25th Jan 2017 5:20pm |
Wired tracker directly to main cable in rear fuse box yesterday. Got in this afternoon after parked on the drive for 24hrs and everything was fine and dandy, no different from any other day, and it turned over and started without any issues.
29th Jan 2017 4:55pm |
Well done Rob... Pete
29th Jan 2017 9:09pm |
Rob, the big red wire in the boot comes to the back via a 100amp fuse at the front, fuses are used to protect the wiring, nothing runs off it until it is split up in the rear fuse box, just to let you know... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
29th Jan 2017 9:15pm |
Thanks Pete
29th Jan 2017 10:26pm |
Um.. Err.... No.... Pete
30th Jan 2017 12:53am |
