Home > Maintenance & Mods (L322) > A word of warning.........and some advice please |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34906 |
the two bulbs do look very similar...... and you might have damaged the ballast when you switched on.. |
27th Jan 2017 6:30pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Can you swap the ballast over, from the other side, to rule it out as the problem. ? |
27th Jan 2017 6:37pm |
ruffy Member Since: 11 Jan 2016 Location: North Yorkshire Posts: 70 |
Thanks for the reply, yes that's the next job as at least the other one is working properly! 1982 SIII 88” diesel
27th Jan 2017 7:00pm |
The ballast is causing the problem genuine Hella replacement ordered from eBay for 38.50 and the incorrect bulb has been returned. 1982 SIII 88” diesel
28th Jan 2017 6:12pm |
