Home > General (L405) > Hard over bumps |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7738 |
Welcome
29th Jan 2017 8:06pm |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 654 |
Which wheel size do you have? and have you checked the tyre pressures? |
29th Jan 2017 9:07pm |
Hardkor Member Since: 29 Jan 2017 Location: London Posts: 4 |
Appreciate the replies .
29th Jan 2017 9:13pm |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
Mine is a reasonably hard ride on the same wheels. I would change them to either 21" or 20" you will find it a much softer ride. I think you will get the knocking sorted out under warranty.
29th Jan 2017 9:17pm |
I'm afraid I haven't got warranty but was wondering if it can be done under a recall issue. |
29th Jan 2017 9:25pm |
22's are less forgiving than the 20's and 21's. My personal preference is the 21's which give a great compromise. Not quite as smooth as 20's but look better IMHO. I'd definitely check the pressures as these can be set for a heavy load and then not set back for normal and it really does make a difference.
29th Jan 2017 9:28pm |
If theres been a recall then yes you should have it done FOC.
29th Jan 2017 9:29pm |
Thanks again for your prompt replies.
29th Jan 2017 9:52pm |
Caddyshack Member Since: 03 May 2017 Location: Guildford Posts: 61 |
Hi All, I have just joined after a few days lurking. Just bought a FF Autobiography from Harwood Pulborough. I mentioned the knocking on front suspension on test drive but was told it was just 22 inch alloys which I planned to change but they wouldn't swap for 20's or 21s off another forecourt car.
3rd May 2017 5:03pm |
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 395 |
I've done 40k + miles on 22" wheels, no significant knocking whatsoever and if they try telling you otherwise dig your heels in. Sounds like salesman talk to me and a car of this quality and price should not have any unusual sounds.
3rd May 2017 5:34pm |
Thanks for the support |
3rd May 2017 6:03pm |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 |
I've got 22's on mine 2016 and it's drives very smoothly with no knocking, hope you get it sorted 2010 defender utility
3rd May 2017 6:46pm |
It is good to hear about the 22's being ok as I like the look but hated the ride. Although I thing a Rangie needs a bit more rubber to handle bumps and kerbs. |
3rd May 2017 6:59pm |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
I have a l405 on 22" and the ride is firm but totally acceptable with no knocking whatsoever. the only time this changed was after its first service when it came out of the workshop with 2 psi extra in the tyres and that made the ride appreciably harder.
4th May 2017 9:39am |
