Home > Technical (L322) > TD6 black smoke on acceleration. |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Hi Glen, did you convert the turbo filter to the vortex type, as that can give those symptoms.
30th Jan 2017 7:25am |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
My TD6 started doing the same, I changed the filter gregdav is talking about and it's a lot less noticeable now! I would recommend the BMW vortex type filter as I didn't and will have to change mine again next year!! |
30th Jan 2017 9:53am |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 |
Sure, I will do the air filter soon, just to eliminate it.
30th Jan 2017 11:53pm |
I seem to recall reading that Land Rover never adopted the vortex, and stuck with the loo roll type filter you describe. When I changed mine it was caked in oil! |
31st Jan 2017 1:49am |
I would say yes, they will still have the loo roll filter. As stacker says, land rover stuck with the bmw m57 engine until the tdv8 took over.
31st Jan 2017 7:32am |
Crazy that LR didn't switch to the vortex breather. I notice that some suppliers are even still selling the 'loo roll' type.
2nd Feb 2017 12:47am |
Best place to start.
2nd Feb 2017 7:30am |
A job for the weekend, if the parts arrive in time.
2nd Feb 2017 9:29pm |
I believe l/r knew they would be phasing out the td6 for the tdv8, so probably thought it wasn't worth it.
2nd Feb 2017 10:34pm |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
Mine started doing this shortly after I bought it at 235000kms.
4th Feb 2017 10:15am |
Finally got round to working on the car this afternoon.
20th Feb 2017 12:41am |
Hi Glen, if the loo roll type filter was full of crap, then that could be giving you back pressure in the crankcase, which I have heard can cause the dipstick to be forced out, I also believe it was the reason for a lot of turbo failures, good you changed it.
20th Feb 2017 9:01am |
Greg,
21st Feb 2017 12:33am |
I'm glad this thread has come up again as I thought at the end of last year I had solved the problem with smoke on acceleration with my car, turns out I haven't.
22nd Feb 2017 12:22am |
