Home > Technical (L322) > Suspension (almost there) |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 |
I posted previously when I was having a few issues with height sensors - cut a long story short I now have the new sensors fitted and attempted to re calibrate the suspension.
4th Feb 2017 3:20am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
You do know you have to have all the doors shut for the suspension to move..??
4th Feb 2017 2:57pm |
Cheers - aware of the doors will investigate the battery thing and see where we go from there - I know some people (including a mate of mine) said its fine the way it is but I am one of those people that would rather everything functions as it should we have a computer here and as mentioned there are no error codes showing on it so I am assuming maybe we just did not carry out the re-calibration procedure properly (I'm not sure what that is if there even is one!) I assumed (maybe wrongly) that once we set the car at normal height the others would just "follow" or do we need to set the height for each setting? |
4th Feb 2017 7:58pm |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
I think it depends what you used to calibrate the suspension?
4th Feb 2017 8:59pm |
You set standard height to calibrate, the other settings are adjustable and you set how much lower than standard access and motorway modes are and how much higher off road is.... They can be set to 0 so nothing happens..
4th Feb 2017 11:10pm |
Cheers again we have two computers, a Solus and the other one (can't remember the model) both work ok but there is more on the other one than the Solus. I'll take another look when I get a chance this week or now its back drive able again a quick blast to a local indy is in order (although that's a 100 mile round trip hence why I try to get stuff done local if possible. |
5th Feb 2017 8:46pm |
Buy an IID tool, it soon pays for itself and then you can do it all yourself, plus get home most times when things go bong away from home....
6th Feb 2017 1:45am |
Been busy so never got back to this, just to report back that a quick blast up the motorway to test that setting and everything is back to normal - Suspension is now working on all heights as before. |
12th Feb 2017 6:44pm |
