Home > Maintenance & Mods (L322) > Quick question on EGR blanking. |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Yes you need to blank the vacuum pipe, that is whst operates the egr.
5th Feb 2017 6:12pm |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
Thanks for that Greg, I just didn't want to throw up any errors since it's actually physically blanked already I though the operation of the valve wouldn't matter but if the consensus is to blank the vacuum then that's certainly not difficult to do.
6th Feb 2017 3:25pm |
You can just screw a brass woodscrew into the end of the vacuum pipe and cable tie it out of the way.
6th Feb 2017 4:17pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
I fitted a blanking kit and now have this error
11th Feb 2017 1:21am |
I fitted a blanking kit and now have this error (2003 TD6)
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
I would check to see if the vacuum hose is properly blocked or has a leak somewhere. It should not cause any issues if the EGR is removed and the hose capped. 2007 TDV8 VSE
11th Feb 2017 3:25am |
That fault I'm sure, always comes up with my iid.
11th Feb 2017 7:15am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Never had it with mine. |
11th Feb 2017 8:20am |
Does yours come up since your blanked the egr? When you say that code always comes up. |
11th Feb 2017 8:30am |
Did you just blank the exhaust side of the egr or fit a EGR delete unit. That code has something to do with airflow and linked with Maf settings according to the BMW forums 2007 TDV8 VSE
11th Feb 2017 11:19am |
The egr was already blanked when I bought the car.
11th Feb 2017 11:28am |
Have you seen this thread? http://www.fullfatrr.com/forum/post396601.html 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
12th Feb 2017 3:28am |
Yes, I read that and no it is not the cause as I replaced those hoses and it did not fix the problem. |
12th Feb 2017 9:29am |
MattyB1983 Member Since: 05 Feb 2017 Location: Cambridge Posts: 81 |
Sorry to jump in but just been out to my car for a look to see if mine had been done prior to me purchasing the car....
12th Feb 2017 3:30pm |
