Home > Technical (L322) > Spoke too soon.. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3059 |
Dirty MAFF?
7th Feb 2017 7:52pm |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 |
Looks like an air/vacuum leak with the associated overcompensation.
7th Feb 2017 7:55pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
It's me giving it gas.. it's perfect over 1000rpm between 800 and 1000rpm is iffy.. mag looks new but could be dodgy I'm thinking |
7th Feb 2017 7:56pm |
Explain electric thermostat fault a bit more?
7th Feb 2017 7:59pm |
Johnny.. I've had this issue before I started working on the car buddy.. will try your method when it stops raining |
7th Feb 2017 8:00pm |
This one
7th Feb 2017 8:04pm |
Check your air filter is correctly attached to the pipe as that can cause rough idling? |
7th Feb 2017 8:06pm |
Ah, just caught up with previous thread. 2007 Vogue TDV8 with 255/55/20's fitted |
7th Feb 2017 8:10pm |
Will double check all connections.. I did remove air box to remove headlight a while back.. had a lot of trouble attaching it at the bottom where the external air intake pipe meets the box.. could that cause it?? |
7th Feb 2017 8:18pm |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
+1, that's where my money would be. |
7th Feb 2017 8:43pm |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
8th Feb 2017 2:07pm |
Looks very much the same until mine gets to 1000rpm then she's perfect. I'm getting it smoke tested for free at the weeekend and if that doesn't give me any resolve I think the maf will be changed.. Pcv systems been overhauled so I can at least rule that out.. mine occasionally dims as well |
8th Feb 2017 9:49pm |
