Home > Maintenance & Mods (L322) > Brake pedal hitting the floor! |
Ollie7195 Member Since: 11 Dec 2016 Location: Somerset Posts: 74 |
Hi everyone,
8th Feb 2017 11:32pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Has the fluid gone down?
9th Feb 2017 8:38am |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
Might be something in here that might help.
9th Feb 2017 12:32pm |
Did you empty your ABS modulator when you change the pipes? It may need "re-jiggling". Some say you can sort of make it do it using the HDC. Don't believe even the IIDTool can do a rejiggle has to be a Testbook or Dealer jobbie. .
9th Feb 2017 6:53pm |
The fluid hadn't dropped over 3 days of good use, would have expected it to have gone down noticeably considering the movement in the pedal, a friend of mine spoke to a garage today and suggested power bleeding it as old fashioned bleeding doesn't seem to overcome the technicalities of modern systems, have tried activating HDC a few times pedal feels a bit stiffer when its on but not much.
9th Feb 2017 8:01pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 498 |
I uesd one of these to flush/replace all the brake fluid on my other car :-
9th Feb 2017 8:56pm |
The other issue may be that air worked its way back into the master cylinder, this is a bit of a problem to resolve.... .
9th Feb 2017 9:51pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Common issue with older cars, before you did any work the piston in the master cylinder was moving a very small amount of it's travel distance to make the brakes work, the last 80% of travel never got used, brake fluid is hygroscopic and absorbs moisture this can corrode the last 80% of the piston bore, when you bled the system you pushed the rubber seal down the rusty bore and damaged them, now fluid is making it's way past the seals and letting the pedal hit the floor...
10th Feb 2017 12:18am |
All good suggestions and quite possible, have bled it all through today after using HDC down a steep hill near by in the hope of emptying air out of the ABS block, good news is HDC works great! but even using the eezi bleed and going through 1.5 litres of brake fluid which flushed all of the old red fluid out and no bubbles at all I still have the exact same issue with absolutely no change.
11th Feb 2017 8:23pm |
