Home > Technical (L322) > Backlash in drivline TDV8 |
SveinHa Member Since: 22 May 2016 Location: Karmøy Posts: 36 |
When maintaining my rear brakes a few days ago, I notice quite a lot of backlash in the driveline. With RR wheel off the ground the rear propeller shaft looks like this (gerbox in "P"):
11th Feb 2017 6:31pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1692 |
Seen quite a few worn front propshafts... |
12th Feb 2017 12:07am |
If the splines are worn, that would only be a part of the problem. There are about 50 splines (roughly counted from the picture) and about 1/16 of one revolution backlash. The propshaft would have to jump 3+(?) splines to get that amount of backlash... "Plentraktoren/Garden tractor": 2008 L322 TDV8
12th Feb 2017 9:21am |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
You could try from the rear wheel end - jack each one up and try turning the wheel, the 'play' may be one of the cv joints on the drive shaft. I had a rear cv go bang - prior to this I was getting a thud each time I went into reverse.
12th Feb 2017 10:11am |
