Home > Technical (L322) > L322 4.2 SC Check Coolant Level |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1270 |
the bleed screw is a poor design , an easy fix is to drill it out and tap it with a 12mm tap
16th Feb 2017 4:47pm |
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 78 |
Yes I had so much air in the system, the temperature fluctuated. I am not saying you need to have the same symptoms, but in my experience, dropping coolant level when revving the engine is a sign of air. Do you have a FBH? In that case this should probably be run also (it has its own circulation pump). I did run mine to flush out air. |
17th Feb 2017 8:00am |
Vergil300 Member Since: 14 Jan 2017 Location: Fife Posts: 39 |
Thanks for the advice Ian, I'm glad it's likely just air...
17th Feb 2017 11:02am |
Agreed but for £20 I can just get a new tank... |
17th Feb 2017 11:03am |
Update.
20th Feb 2017 4:29pm |
Update on this.
24th Mar 2017 10:10am |
Update on this... (probably related)
14th Apr 2017 8:27am |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
99% sure mine has had a water pump, but drove to Czech Republic and kept getting low coolant warning message on dash.
15th Apr 2017 9:13am |
