Home > Technical (L322) > Coolant query on a TDV8 |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3192 |
"With the engine cold in the morning I have checked and it has dropped abit "
19th Feb 2017 2:48pm |
SteveRRL322 Member Since: 23 Oct 2016 Location: Kent Posts: 128 |
Thanks
19th Feb 2017 3:27pm |
Sounds like an airlock clearing. The level will vary with engine temp. Leave it alone for a while and then check it. Try not to take the cap off when the engine is warm as the system will be under pressure hence why you saw the level go up.
19th Feb 2017 4:32pm |
Ok thanks I will keep an eye on it |
19th Feb 2017 9:17pm |
oh and only check the coolant level when cold. so in the mornings is best. There is nothing that can't be fixed with a hammer😜😜
19th Feb 2017 9:34pm |
Good morning,
13th Mar 2017 11:43am |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 |
Do a search on thermostat housings.
13th Mar 2017 8:03pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I would wait to see if the coolant level settles down. I think mine had some thing similar. The Indy re-bled it and put stop leak through it. This after it was flushed. It now moves between the two marks on the bottle.
13th Mar 2017 9:26pm |
Thanks for the comments so far.
2nd Apr 2017 10:49am |
coolant doesn't really cycle through the header tank, its basically just an expansion vessel. There is nothing that can't be fixed with a hammer😜😜
2nd Apr 2017 11:01am |
Thanks NMJ
2nd Apr 2017 11:07am |
never really checked to be honest Im off out in a min will see if my 4.4 tdv8 gets hot. There is nothing that can't be fixed with a hammer😜😜
2nd Apr 2017 11:09am |
👍 cheers |
2nd Apr 2017 11:20am |
coolant is pretty warm in the expansion bottle after a run out. so you might have an air lock. keep bleeding air out of the screw on the top of the expansion bottle. There is nothing that can't be fixed with a hammer😜😜
2nd Apr 2017 12:57pm |
