[Sold] 2002-2005 g9 Genuine Bluetooth module- full dash | |
Hi all though I'd advertise here first
I have a gen 9 bmw Bluetooth module I am removing as part of my massive entertainment project.
Don't remember what I payed but anything newer than gen 5 is not cheap and needed for the newer phones.
If you have this you will be able to scroll and dial contacts on your instrument cluster! This is very handy.
If you have a vogue this is a very very straight forward retrofit.
You have the wiring already in the boot minus an antenna which I bought from China for £10 which is perfect. This needs a repin.
Then You need a mic I bought one out of an e39 for £10 these don't change. Wiring already up front. No repinning here.
You then just need a pairing button to wire to the module - 2 wires very easy - or if you have an intravenous you can skip this bit!
Once the above is done you will have telephone available on the nav and dash all working!
No need for coding!
£100 for the module plus £10 postage if needed cheers.
