Home > Technical (L322) > L322 2006 Air Suspension Issues |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Probably best to leave the compressor in place, otherwise you will be guaranteed to be running at 35 and have an extremely bumpy ride. Have you got a leak? or pinhole in one of the bags? If you can get it in to high, switch off the engine and go for a stroll around the car.. anything sounding like an angry snake and you've found the problem Yesterday I couldn't spell Engineer... Today I are one!
20th Feb 2017 6:24pm |
Vergil300 Member Since: 14 Jan 2017 Location: Fife Posts: 39 |
Think I've found the problem, one of the blue pipes coming from the car.
20th Feb 2017 8:43pm |
That rather depends on where the damage is, providing that there is sufficient good pipe between the hole and the nut then you might get away with a Commercial Air Brake straight coupler, they are push fit and come in allsorts of sizes, but you would need about 1/2 inch stub on the nut for it to grab. Not being funny but it might pay to seek out a commercial vehicle specialist, possible even a mobile fitter, as they deal with that nylon pipe day in day out... it's used for the brakes, suspension, clutch, seats, PTO, remote levers on a lorry and much more! Yesterday I couldn't spell Engineer... Today I are one!
20th Feb 2017 9:11pm |
just had a thought it could be wrapped with some rubber and jubilee clip tightened over the top.. it's a real bodge.. but it does work
20th Feb 2017 9:16pm |
Yeah might get someone professional to have a look...
20th Feb 2017 9:41pm |
On that same vain depending what the blue lines are, would some silicone do? |
20th Feb 2017 9:49pm |
At 13 bar you'll be lucky! If the blue lines are not on the pump, I would assume that they are the main F/R feed pipes, if you know where it's going, why not look it up on Microcat and get the part number, then google that number and if your lucky you'll end up the price and possibly a bargain too
20th Feb 2017 10:02pm |
Thanks for that link, it's super helpful!
21st Feb 2017 10:26am |
Update on this.
27th Feb 2017 5:05pm |
Hi all,
10th Mar 2017 4:17pm |
Buy a new compressor!
24th Mar 2017 10:39am |
