Home > Technical (L322) > Won't turn over,ignition module fault, how to remove it ? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3192 |
A screw bit in a quarter inch ratchet. Gives you a right angle access. John
26th Feb 2017 4:01pm |
desertdude Member Since: 10 Sep 2016 Location: Dubai Posts: 60 |
No you can't do that on the side where the key goes in, there ignition barrel right up against the screw head you can even barely see it.
26th Feb 2017 7:10pm |
Yes , sorry I was looking at the wrong side. I did mine last month and it was straightforward. You don't need to take out as much as at first appears.
26th Feb 2017 7:53pm |
Thanks, I will have another poke around tomorrow again to see if I can locate that forward screw under the lip you mention and see if I can wiggle out the ignition barrel from under neat.
26th Feb 2017 9:03pm |
There are two screws to come out, one on either side.
26th Feb 2017 9:17pm |
Yes sorry screws and not screw is what I meant to say. Btw they open from the outside or the inside like the pic I posted? |
26th Feb 2017 9:44pm |
Sorry I'm not clear what you mean. The points of the screws point forward towards the front of the car, for want of a better description. John
26th Feb 2017 10:00pm |
Yup clear enough and that's what I wanted to know. Thanks |
26th Feb 2017 11:05pm |
