Home > Other Site Sponsors > 20% off Heatshield Products and Magnetic Gold Plugs!
oilman
Opies are pleased to announce that we will be running a very special offer for the whole of March on a couple of our very popular brands: Heatshield Products for thermal protection, and Gold Plugs magnetic oil drain plugs. You will be able to get a massive 20% discount on all products from these ranges - all you need to do is enter the code: HG20 at checkout to get these fantastic products at a fantastic price. Simple!
To make you aware, only one discount code can be used at a time, but this code will work on all products from both brands
This offer is our way of giving you guys a bit of a boost in time for the summer. If you've got any track days or the like planned, then now is the time to be cracking on with any work you've got planned on your vehicle, and all the products from Gold Plug and Heatshield are designed from the ground up to improve the running of your car. For a little bit of info on both brands, have a look below.
Heatshield Products - Top of the range thermal insulation, all the way from the USA
HeatShield Products was established in 1985 as a family owned and operated business, and has gone from strength to strength ever since. A huge name in the states, they are recognised for the impressive work they have done with NASCAR racing, competitive off roading and an array of other performance motorsports. As you can imagine, with over 30 years of experience in this highly demanding area, their products offer the best performing heat shields, exhaust wraps, heat protective sleeves and thermal insulation around.
Engines and all of their components create very high temperatures and are under a lot of stress when operating at performance levels. If you have a modified vehicle, then we have the Heatshield Product to give you that edge you are after, and the peace of mind that you're covered during track days and competitions. On our website, you will find relevant and concise information on exactly what you can expect from their products, from the benefits gained, to the precise temperatures that they can take. This allows you to browse through and find exactly what you need for your specific set-up, as well as giving your car or turbo that custom look!
The fully comprehensive range can be found HERE, and have a look below if you know what you're after:
- Automotive Heat Shields: For improved reliability, improved efficiency and performance.
- Exhaust Wraps: Retains heat in your exhaust system to create hotter gases, allowing faster flow of exhaust.
- Hose Protection: Keep components cool, but also keep you moving! Shielding fuel lines can prevent vapor lock and cavitation.
- Thermal Barriers: Designed to shield radiant heat, important for those days on track.
- Thermal Insulation Tapes: Reflect radiant heat away from wires, lines, cables, and hoses. Reflective heat shield on one side, high-temp adhesive on the other.
- Thermal Ties: Stainless steel locking ties, the easiest and best way to fasten any type of high temperature insulation.
- Turbo Shields: Improve the efficiency of your turbo by retaining heat inside with a heat shield. Using a turbo bag can increase boost, reduce turbo chatter or flutter, keep the turbo from lagging.
Combining cutting edge technology and constructed with the highest quality materials, Heatshield has got you covered, and with this 20% discount accross the entire range, there are some absolute bargains to be had!
Magnetic Sump Plugs from Gold Plug - The last drain plug you'll ever need!
Another American company, Gold Plug was started in 2001, simply because they were fed up of not being able to find a good quality magnetic drain plug for their street bike engine that they had just finished rebuilding. After searching high and low, Gold Plug was born. Now, their daily mission is to supply the very best magnetic drain plugs to keep your vehicle running in the best possible condition. Why choose a magnetic oil plug over a standard sump plug you ask? Well, there's quite a few reasons actually.
Every time you run your engine, there will be a build up of contamination in the form of thousands and thousands of very small particles of ferrous metal. The main cause for these microscopic particles is friction, and you can imagine how much of this is generated when driving hard. To put things in perspective, an engine travelling at just 2000rpm sends the pistons up and down the bore 33 times per second. Imagine what a day on track is doing to your engine!
The oil filter does its part in keeping these filtered, however they can only filter out particles larger than 35 microns. These nano particles of metal suspended in the oil are considerably smaller than this, and to top it all off, the smaller the particle, the more damage they can do - This is because they travel pretty much anywhere in your engine when under hydraulic pressure. The only way to "trap" these particles is with very strong magnetism.
You can find them HERE. If you fancy a look at exactly how magnetic sump plugs work, you will find a handy video on each product page. Have a look below for links to just a few of the vehicles they cover:
- [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(434)@*ava=0]Subaru[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(430)@*ava=0]Nissan[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(423)@*ava=0]Mitsubishi[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(447)@*ava=0]BMW[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(438)@*ava=0]Honda[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(437)@*ava=0]Audi[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(435)@*ava=0]Mercedes[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(429)@*ava=0]Toyota[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(421)@*ava=0]Ford[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(443)@*ava=0]Peugot[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(439)@*ava=0]Mazda[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(436)@*ava=0]Volkswagen[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(444)@*ava=0]Renault[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(433)@*ava=0]Volvo[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(432)@*ava=0]Land Rover[/url] - [url=http://www.opieoils.co.uk/c-2489-gold-plug.aspx#Filter=[EntityIDs=@(427)@*ava=0]Mini[/url] -
Gold Plug have designed their range to fit over 100,000 cars and motorbikes, so if you need any advice on the correct one for you, then please get in touch. Why rely on just any old drain plug, when you can have one from Gold Plug that saves your engine from the wear and tear of metal particles?
One last time, that code is: HG20 and is running until the end of March, so if you want to get 20% off either of these great brands, you'll want to get these orders in as soon as you can.
It's also worth keeping an eye on our current offers page HERE. There's all sorts of goodies to be found!
If you've got something a bit special and need a bit of advice, then give us a ring for a bespoke and impartial recommendation that is tailored to your specific set up. We're in the office Monday to Friday 8:30 - 5:30, on 01209 202 944 and sales@opieoils.co.uk. You can also drop us a message on here.
Until next time,
Oilman Use the code FULLCHAT and get 10% Club Discount
oilman's website: www.opieoils.co.uk - register for news and offers www.opieoils.co.uk
email: sales@opieoils.co.uk
phone: 01209 202944
Post #429853 3rd Mar 2017 12:36pm
