Home > Maintenance & Mods (L322) > Number plate lights
Rafterman
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Java Black
Number plate lights
Just replaced all my interior lights to led all working fine and a much better light now. Also changed the number plate lights which work ok but when standing at the back of the car to check them I could see a reflection of the LEDs on the paintwork under the number plate which is showing as a white light. Any one else had this or should I stop polishing the back of the FF Whistle The worst thing about being retired is you miss out on all the bank holidays
Post #430237 6th Mar 2017 5:03pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
would you mean like this ? I upgraded mine this afternoon amazingly bright did you change just the bulbs ?
my number plate camera gets in the way a little, may have to re-think the camera
Post #430511 8th Mar 2017 9:58pm
Rafterman
Lukie sorry for the delay in replying I have in up in the Lakes for a few days. Yes that is it, the reason for my concern about the white light to the rear is because on my last MOT I got a fail due to one of the diadem bulbs (stop and tail) which the SC have fitted was showing a slight white light because a small area of the coating on the bulb had come off. Replaced the bulb and got a pass the same day. I may consider putting the old bulbs back for the next MOT. But in the meantime the old bill should get a good view of my number. Whistle The worst thing about being retired is you miss out on all the bank holidays
Post #431329 15th Mar 2017 5:52pm
Lukie
if they are there and they work sod them ! I'm actually think of removing my bulbs from factory number plate fittings and go for LED fittings inside the number plate / reverse camera surround
the LED's are mega bright but I feel give to much shadowing to my car
Post #431351 15th Mar 2017 9:01pm
Rafterman
I see what you mean about the shadowing can you twist the bulbs more to face the number plate and see if that stops the shadowing I did it with mine to try and stop the reflection on the paintwork and it did light up the plate better but still reflects. As you say sod it The worst thing about being retired is you miss out on all the bank holidays
Post #431356 15th Mar 2017 9:39pm
Lukie
the conversion I did to my number plate lights were not bulbs but PCB insert's I purchased X5 ones and carefully removed the PCB and inserted them into my range rover lenses
the PCB's fit nicely into the range rover number plate light holders
the shadowing on my car is due to the number plate surround that holds a camera this sticks out 1.5-2 inch's
Post #431526 17th Mar 2017 8:22pm
