Home > Maintenance & Mods (L322) > Coil pack |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
Could you turn the engine off when the problem is manifesting itself, take the plugs out and see which are wet with unburned fuel? I recall doing that with a RR Classic when there was a coil short problem, alas some of the plugs could not be shifted. I expect there is a more sophisticated method using a meter on the electrics, or plugging into diagnostics. Only Range Rovers since 1988 |
8th Mar 2017 4:20pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
As CS says, take all your plugs out to look for an odd one and then swap the coil pack with a plug that looks good and see if it moves and diagnostics with live data like a faultmate will give you a roughness value for each cylinder |
8th Mar 2017 11:59pm |
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 |
Thanks for the replys, but the miss is irregular and buy the time i let the engine cool down and get the plugs out i may not see any difference. I have the iidtool but that doesn,t show anything. I have one new coil pack and i suppose i could swop it over with No. 1 plug and then No. 2 and so on, but that would be a real hit and miss(no pun intended). |
9th Mar 2017 12:58am |
If a cylinder has been behaving badly for a while you may see a difference in the carbon deposit on it rather than it just being wet as i think the injector is turned off for the cylinder that isn't sparking, I only read that somewhere so not sure if that is true though ... |
9th Mar 2017 7:53am |
Thanks for thecomment, i am going to have a look today, just waiting for the motor to cool down a bit, took it for a good run around town and no miss but i get the shivers each time it does so i will dig deeper |
9th Mar 2017 8:11am |
