Home > Technical (L322) > Hazards not flashing when locking and unlocking l322 |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
Generally needs coding to enable flashers etc. Regards
11th Mar 2017 9:39pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 818 |
Hi,
11th Mar 2017 9:51pm |
S14WNO Member Since: 10 Mar 2017 Location: Lancs Posts: 24 |
So i will need to get it plugged into diagnostics to code it? |
12th Mar 2017 10:55am |
It's a dealer only procedure unless you have an IIDtool then you can customise it yourself.... ______________________________
12th Mar 2017 11:37am |
May have to invest in the iid tool then |
12th Mar 2017 12:11pm |
There are loads of threads on here about the IIDtool, they may be pricey but they save money even in the short term.
12th Mar 2017 12:19pm |
I had the lock / unlock without the hazards flashing, turned out the upper tailgate wasn't fully closed when I locked the car even though it looked fully closed. Opened the tailgate shut it purposefully and everything ok again. Worth a try. |
12th Mar 2017 12:45pm |
Saying that, how does your lower tailgate work?? I have to flip like a switch on each side for it to be able to close... and i though my upper tailgate wasnt closing properly. Have to check that out |
12th Mar 2017 6:28pm |
My lower tailgate locks fine with the electric locking, you should't need to operate the lock catches by hand. One of my lower tailgate locks didn't work initially which I corrected by moving the body latching plate towards the rear of the car a small amount. |
12th Mar 2017 6:45pm |
See mine doesnt lock like that, this is my first range rover so didnt know any different... |
12th Mar 2017 7:56pm |
Sorry I have misled you.
12th Mar 2017 10:10pm |
Yes i can hear it unlock when i press the button but its closing it afterwards... i have to click back the notches on each side to be able to close it, it doesnt close electronically. The guy i got the range rover off told me this is how its meant to be done and showed me what to do, said he didnt know how to do it either when he got the car but i think he was playing dumb as i have found a lot of issues that he wouldnt of missed after a long period of time owning the car, one being the suspension (he told me he thought it went up and down on its own when you went onto the motorway and he didnt know you could control it via the dash control) i guess im more of a mug for falling for his sh** to start off with lol. If i get a break from my 11 month old tomorrow i will look at taking the mechanism apart and cleaning it up the best i can... see if that does the trick. Im hopibg this could be the reason my lights are not flashing |
12th Mar 2017 10:21pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7628 |
On my td6 I had one side that was sticky, I just loosened it with some WD40... that said, the electric bit was working.... you can hear it try when you press the recessed button.... 2011 Range Rover Vogue SE 4.4 TDV8
12th Mar 2017 10:41pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 761 |
Or deadlocking...
13th Mar 2017 7:08am |
