Home > Technical (L322) > td6/v8 anyone got rid of the gear stick for a rotary panel?
javal322
2005 Range Rover Vogue Td6 Java Black
as it says in the title really , just wondering if anyone has ever got rid of the gear stick and switched to a rotary type or similair?
i have seen with the paddle shifts you can do manual gear selection ect but not sure how the box works so are the other functions electronic and just the park operated from the cable?
would be nice to have the newer look interior mainly
Post #431548 18th Mar 2017 1:13am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi mate
I'm the one that created the paddle shift update so know about the transmissions, the pre rotary gear shift transmissions use cable operated selectors for all its positions P R N D. Only the very later L322s use electronic transmission selectors.
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #431549 18th Mar 2017 1:28am
miggit
You'd need to fit an electronic shift actuator and then control it with the rotary switch.. possible, but a lot of work..
There are a few cars out there with remote selectors but most of them are only a few years old, so they will more that likely be ECU controlled stepper motors... the only car that springs to mind that would have a simpler analogue system is the Rolls Royce / Bentley's from the late 80's early 90's, they had a fly by wire gear shift, resembles a windscreen wiper motor! Yesterday I couldn't spell Engineer... Today I are one!
Post #431567 18th Mar 2017 2:11pm
javal322
thanks guys i thought it would be a long shot , just wanted to tidy the cab up a bit and give it a more modern look but not in a rush to get of my td6 so would prefer to update it rather than replace it
Post #431569 18th Mar 2017 2:25pm
