Home > Maintenance & Mods (L322) > Power steering hoses fitting advice required |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 895 |
I replaced the lower hose on my 3.6 TDV8 last year and it was a straight forward job.
20th Mar 2017 11:05am |
johnb8538 Member Since: 15 Sep 2016 Location: Glasshoughton Posts: 71 |
Thanks Mike.
20th Mar 2017 11:22am |
It was the other end that was leaking on mine.....where the hoses connect to the cooler.
20th Mar 2017 1:45pm |
If it's leaking at one of the banjo unions I would try replacing (or annealing) the copper washers first. If they look OK when you take them off just warm them gently with a blowlamp which will soften the copper. Or, best bet is fit new ones. |
20th Mar 2017 3:19pm |
Just to make things more interesting....
22nd Mar 2017 11:04pm |
Sorry I meant to add.
22nd Mar 2017 11:11pm |
As it was a lovely day I investigated further.
25th Mar 2017 10:12pm |
It helps when you use the correct diagram!
25th Mar 2017 11:20pm |
A million to one chance combined with poor workmanship I guess.
1st Apr 2017 2:12pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
Just my 2 pence worth, but That would just be a band aid repair, if the hose is split there then it must be perishing, and will fail some where else later, best replace with a new one and have piece of mind than ave a major leak when you don't want it. |
1st Apr 2017 2:43pm |
Totally agree on replacement but just wondered if a "bodge" would stem the leak for now.
1st Apr 2017 9:10pm |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 220 |
I have just replaced the two pipes from the steering rack.
11th Sep 2021 6:45pm |
