Home > Technical (L322) > steering Angle sensor
Dave 1979
England 2002 Range Rover Vogue Td6 Barolo Black
Hi just after some help, I've replaced the steering Angle sensor today and now the horn or any of the steering wheel controls work I've checked the fuses etc any one had this many thanks
Post #431804 20th Mar 2017 7:41pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
It looks like you may have left a multiplug unplugged probably from the rotary coupler on the upper steering column, as the rotary coupler has the connections for the horn and controls etc.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #431810 20th Mar 2017 8:05pm
Dave 1979
I've checked the connections I didn't undo any 🤔 Do you know which one it is?
Post #431830 20th Mar 2017 9:26pm
UK Marine
Hi,
I had a quick look on my wiring diagram but it'll be easier if you have a quick look in the wiki above and go down to the electrical diagrams.
It's either that or a battery disconnect to reset the ECUs. There's a procedure for the battery disconnect in the wiki also and a description for an ECU reset, you never know it might work because these cars do like to get their knickers in a twist Thumbs Up
Best of luck... ______________________________
Simon
Post #431832 20th Mar 2017 9:33pm
Dave 1979
Hi I'm being stupid now what's the wiki please
Post #431835 20th Mar 2017 9:49pm
UK Marine
Go up the the top right of this page and you'll see Forum, Gallery, Wiki etc it's a place where there are detailed instructions on how to carry out various procedures.
Are you aware that you'll need to recalibrate the new starring angle sensor. Some people call it coding it to the car but all you need to do is recalibrate it, it's done with an IIDtool from GAP (lots of threads on the forum about it) or a dealer / independent level diagnostics machine. If you don't recalibrate you'll get a few errors regarding suspension etc.
Simon
Post #431849 20th Mar 2017 10:40pm
