Home > Maintenance & Mods (L322) > Gearbox wiring loom seal leaking |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1691 |
It takes around 90 minutes, start to finish
23rd Mar 2017 9:25pm |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 220 |
I followed this. Think it is the same thing.
24th Mar 2017 1:17pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
Thanks Guys , will order a new seal, sump and fluid from Dan.
24th Mar 2017 3:34pm |
the gearbox needs draining simply to get at the release for the sleeve
24th Mar 2017 5:24pm |
Well,all done, at a cost of £300 ish (£10 for seal, the rest on new sump pan and transmission fluid). If anyone else is going to change their sump pan / transmission fluid, I suggest replacing this seal at the same time - if I had known it was a common failure, I would have replaced it 18 months ago when i changed the transmisson fluid - have just had to ditch £175 worth of fluid which had only done 20,000 miles 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
21st Apr 2017 3:19pm |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 |
Well done.
21st Apr 2017 5:28pm |
It's an issue on all the 6HP boxes |
21st Apr 2017 6:33pm |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 |
If it makes you feel any better , you didn't get all the old oil out originally so all you just lost was diluted old fluid !!! |
22nd Apr 2017 8:36pm |
No, having changed it 3 times originally, there was very little old fluid in there, which was borne out by the clean colour of what I drained out this time 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
1st May 2017 12:32pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2304 |
ZF recommend changing the seal any time the pan is removed to avoid this situation. |
1st May 2017 9:45pm |
Just a thought - as you knew the oil was fresh, you could have drained it and simply re-used it?
2nd May 2017 3:13pm |
It's a problem keeping it completely clean.
2nd May 2017 6:49pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
http://www.roverparts.com/resources/videos...ing-light/ A great video here shows you how it is done ! |
2nd May 2017 9:24pm |
http://www.jpat.co.uk/ You are as well changing the temp sensor including the transmission harness at the same time,you can get one here for less than £100 delivered |
2nd May 2017 9:39pm |
