Home > Technical (L322) > EXTERIOR REAR VIEW MIRRORs
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
I suppose that in my 2002 L322 the exterior rear view mirrors are power fold correct?
Only one (driver side) LHD work but, not fixed (came and go) when I hit the door button .
What can be the problema? Is this expensive to repair?
Cheers
Antonio
Post #432376 23rd Mar 2017 11:40pm
miggit
Try this http://www.fullfatrr.com/forum/post162506.html#162506
It's a common fault on older cars, I just left the mirrors out and never folded them on mine, if you don't want to strip the mirror and you fit a replacement you will find that they are very expensive £200 second hand / used and up to 3 times that new, depending on what spec mirrors you have.
FYI you could get repair parts (gears, motor cases, etc.) for the BMW X5 mirrors, which I believe have the same folding motors as the 2002-2005 ffrr... also the micro switch can play up inside the mirror. Yesterday I couldn't spell Engineer... Today I are one!
Post #432381 24th Mar 2017 12:01am
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Chances are that if the mirror folds in but immediately folds out again, it's an issue with the microswitch inside the mirror housing. There's a link in the Wiki about it.
One of mine was doing the same. When I pulled the back of the housing off to get at the microswitch, I found the arm had come off the microswitch. Just reattached it and the mirror works again. 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #432421 24th Mar 2017 12:50pm
miggit
A.Pires says that only one mirror is moving, so I suspect that it's a gear problem in the mirror... if one mirror doesn't fold the system goes back to it's previous state... so the working mirror will go back out again.... yes it's technically a micro switch fault as one is not showing the closed position, but I think you'll find it's because there is no movement on 1 of the mirrors Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #432485 24th Mar 2017 6:50pm
