Home > Maintenance & Mods (L322) > Td6 de-cat pipe.
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Td6 de-cat pipe.
Anyone know where I can source a de-cat pipe for the Td6?
There was a company advertising a stainless one on E-bay for £99-00 but they don't seem to be listing it anymore.
Post #432476 24th Mar 2017 6:10pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
I don't think you're allowed to doit Glen.
afaik the mot will pick it up.
I stand corrected if anyone knows better.
If it is possible, then would be a good mod.
Greg. Thumbs Up
Post #432506 24th Mar 2017 7:58pm
GDM
Greg,
I am pretty sure you can on a diesel, as it is only tested for visible smoke. I de-catted my old 320d with no issues at MOT time.
Glen.
Post #432533 24th Mar 2017 11:04pm
miggit
I think you'll find that it is required for the MOT, unless you've found a blind tester.. If you want it De-catted then the only trouble free way that I know is remove it and either brake out the innards with a long screwdriver / chisel, or cut open the top (not seen part Wink ) gut it and weld it back up.. One way is quick but requires welding skills, and the other is tedious and time consuming.. but most monkeys should be able to do it Laughing
And if you go for the hammer / chisel option make sure it's all out, otherwise I predict a post entitled "I've got a loud rattling noise coming from underneath" Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #432544 25th Mar 2017 1:37am
gregdav
Done a little bit of reading, and it seams to be a bit of a grey area.
depends how jobs worth your mot tester is, I know mine would say it's a complete load of b Censored x on a diesel, but there may be others who will say this year and model should have one fitted.
I think miggets idea of taking the innards out is the best solution, because the tester can see it there but can't test it Laughing
some good reading.
Greg. Thumbs Up
Post #432675 26th Mar 2017 8:02am
GDM
I managed to find the company on e-bay who were doing the Td6 de-cat pipes, they also do quite a few for BMWs. I messaged them but they never came back to me.
I don't think my usual garage would have a problem with the MOT, if I removed the cat, but gutting it might be the safest option.
I am having turbo issues at the moment. The original one was whining so my garage fitted a recon one and it immediately leaked oil into the intercooler and smoked like hell. I should find out on Monday if it is faulty.
Post #433550 2nd Apr 2017 11:06am
gregdav
Hells bells mate, your having a bit of a mare.
the cat on mine rattles at 900-1000 rpm, I promised myself I'll get it off and sort it one of these days.
Hope it goes ok for you with the turbo .
Greg.
Post #433598 2nd Apr 2017 7:56pm
GDM
Greg,
Yes, the recon turbo problem is annoying. I went to a company that were really helpful with an Iveco truck turbo a couple of years ago. They collected the dodgy recon one and the original (to see what the failure was on that one) on Friday and they should be getting back to me tomorrow with their findings. With the old turbo there was absolutely no smoke, just a whine. The garage did say, the one plus point was that the whine had gone with the recon turbo fitted!
Post #433628 2nd Apr 2017 10:31pm
