Home > Maintenance & Mods (L322) > Rear tire feathering
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
OK folks this is just on the right rear. I just installed my 8/32 evenly worn tires back on and balanced. Alignment was done about 5k miles back. The set I removed were down to 4-/32 except the right rear which was at 2/32. I have about 1k miles on this set and see the right rear is feathering. I will have alignment rechecked this week. Any other known culprits to this? Thanks.
Post #432668 26th Mar 2017 4:15am
The brand of tyre can make a difference.
By way of an example, Continentals were standard fitment on my SC and they're known to show outside edge feathering, as indeed were the ones supplied on mine when I bought it, yet the Pirelli Scorpions I've had for the last 3 years have been fine. Si. <This is my name.
Post #432693 26th Mar 2017 11:39am
doclees
Pirelli Scorpion MS. Remember it's just the right rear tire.
Post #432735 26th Mar 2017 4:46pm
Rangeyman
Mine were like that when I bought it more so on one side but am sure both rears were affected and they were Pirellis,i only do low miles so not really noticed on the newer tyres as yet.I guess all you can do is replace bushes at the rear which may only have slight wear but may be the culprit but you have a few to choose from .
Get a second opinion from another alignment centre.
Post #432897 27th Mar 2017 7:50pm
doclees
I appear to have this sorted out. Seems the toe was off on all 4. Worse on the right rear. I guess I will need to have alignment checked every 3 months on this car. Here in PA you can off road while on the highway.
Post #436426 30th Apr 2017 3:08am
nino_nino
It may be a good idea to change the place You do alignment at. Wink
Post #436428 30th Apr 2017 5:12am
doclees
I have a 3 yr alignment deal. I haven't had problems with my other cars but none were 5400 lbs. Think I'm going to need a balance deal too. They said the larger tires needed balanced more frequently too. Maybe 3k miles and I can begin to feel the front vibration.
Post #436678 2nd May 2017 3:03am
