Home > Maintenance & Mods (L322) > Heater/climate unit not changing temperature |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
Had an issue with the heater controls since putting it back on the road in October. If you turn up the drivers side, it stays cold and then randomly it will go hot a while later and you can't seem to turn down the passenger side from hot to cold. You can turn the knobs but the temp doesn't change. 2004 RR 4.4 V8 Autobiography |
26th Mar 2017 2:08pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
Does it work if you put it on full hot or full cold? |
26th Mar 2017 5:53pm |
Hi, if you put drivers side up on full hot it stays cold then it might randomly go hot. Passenger side never turns down from hot whatever you do. The vent by the knobs is covered in dust actually as I haven't had chance to clean it out since being back on the road. The vent flaps in the wings is also sounding like a possibility, didn't even know about those either. Does anybody have any pictures of the vent flaps so i know what to look for? 2004 RR 4.4 V8 Autobiography |
27th Mar 2017 9:44am |
Cleaning the dash sensor hole is the easiest thing to try, and quite likely. AIUI the temp controls are relative temp really, not an absolute temp. The sides can only be (I think) 6 degrees apart, so you can't have one on full hot and one on full cold. In the user manual! |
27th Mar 2017 11:02am |
