Home > Wheels & Tyres > Diamond cutting or polishing alloys...... |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
As per my previous thread about swapping my 19" wheels for a set of 18" purely because I already have a set of tyres, I purchased these wheels yesterday......
5th Apr 2017 3:47pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1340 |
Presumably one would need to apply some kind of paint stripper to get the lacquer off and then polish out the corroded run marks that have eaten into the wheel surface underneath. They would otherwise remain visible under the new lacquer. Only Range Rovers since 1988 |
6th Apr 2017 10:41am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1688 |
Lacquer needs removed, marks polished from the wheel surface, and relacquered to repair
6th Apr 2017 11:52am |
Thanks for the replies, there often seems to be an issue sealing bare aluminium. |
6th Apr 2017 3:07pm |
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 |
On my last car the wheels were diamond cut...which had gone horrible under the lacquer...so I removed the diamond cut and polished them...no lacquer afterwards... 6 years on and they still looked like new with the occasional application of Autosol... |
8th Apr 2017 10:17pm |
Thanks for that Zeb, I think I might go down that route myself.
10th Apr 2017 2:03pm |
10th Apr 2017 11:15pm |
daveenty Member Since: 30 Mar 2016 Location: North West Posts: 34 |
I would also agree that this is the best way, as long as you don't mind breaking the polish out occasionally. The problem with the lacquer is that, like all finishes, it needs a decent key to adhere to which a polished surface by it's nature cannot give it so it starts to split. Add in the odd stone chip and the "spider legging" starts to appear, which then means the lot has to come off again. I just paint mine now as I can't be bothered polishing them all the time but they don't look as good as polished alloy. Dave 2010 5.0 Autobiography |
11th Apr 2017 9:18am |
Any opinions on this?
14th Apr 2017 1:42pm |
I like that... |
16th Apr 2017 2:10am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
16th Apr 2017 5:09am |
mikeyyn Member Since: 17 Oct 2011 Location: Notts Posts: 53 |
Hope I'm not hijacking the thread, apologies if so....Does anyone know a good wheel refurb place (tyres off and full strip etc) near Sheffield/Donny way? |
16th Apr 2017 9:45am |
lazylabs Member Since: 01 Nov 2016 Location: Lincoln Posts: 78 |
Try arefurbs in Doncaster.
16th Apr 2017 3:30pm |
First wheel stripped and polished, but not painted.
29th Apr 2017 3:40pm |
