Home > Technical (L322) > Low vibration ,droning,buzzing sound..
Rover T
Ireland 2012 Range Rover Vogue TDV8 Epsom Green
Got the car serviced recently and the software updated, they changed both front brake flexis as well for a recall issue, since the car is back there seems to be a very low buzzing,vibration from the top of the engine area under the cover at idle. Once the car moves off the sound stops but when slowing down again at lower speeds and engine revs the sound appears. It seems to change with the engine rev as the car slows down.?? Sad
Post #434084 6th Apr 2017 9:38pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Fill in your car profile so as members on here know what model, year and engine. Thumbs Up
Post #434085 6th Apr 2017 9:48pm
alistairh
Like this by chance?
Post #434086 6th Apr 2017 9:53pm
Rover T
Sorry gregdav,thought I had filled it out . The noise is only there with engine running.
Post #434093 6th Apr 2017 11:21pm
gregdav
Maybe they have not tightened a cover or something down properly.
It maybe a resonance issue, and will only vibrate at those Rev's, does it do it if you just rev the engine?.
Of course your other alternative is to go back to whoever serviced it..
good luck. Greg. Thumbs Up
Post #434106 7th Apr 2017 5:21am
Rover T
Main dealer serviced,after giving it a quick check it sounds like its from the fuel pump? No light or symptoms yet?
Post #434130 7th Apr 2017 9:54am
