Home > Technical (L322) > Oil in spark plug well. |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Indication of oil high up on the cover..gaskets?
13th Apr 2017 6:43pm |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Hi Alistair, your profile doesn't say what FFRR you have......
13th Apr 2017 7:28pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
err, alistairs profile is visible if you click on or hover your mouse over the little car underneath the username.. ... - .- -.
13th Apr 2017 7:35pm |
Thanks for reply.. cam covers will be the next job on the cards I think. Already evidence of a leak on the underside of engine as well.. did the Pcv system already and I suspect the engine mess is because of this.. |
13th Apr 2017 8:03pm |
One thing I've noted since changing the plugs is my dodgy idle that would fluctuate between 800/1000rpm is gone? Reckon I've found the culprit( I hope) 👍 |
13th Apr 2017 8:09pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
If you have oil at the front of the engine then your vanos solenoid seals and upper timing cover gaskets are probably also shot.
13th Apr 2017 11:31pm |
Will do is the vanos seal a big job interms of access? If not I may do both sets at the same time. |
14th Apr 2017 7:35am |
The vanos solenoid seals is easy, just two bolts, you could do the non return valves at the same time with the use of a special deep socket and long M10 fine pitch bolt. You can see where the seals sit in my fots of the left and right bank.
14th Apr 2017 9:23am |
Brilliant. That's a huge help buddy. Will get all the seals ordered today. Thanks again |
14th Apr 2017 10:07am |
Ordering cam and vanos gaskets today, what Else do I need to order? Screws/bolts for cam covers? Not too sure and I want to have it all at hand . Thanks |
14th Apr 2017 10:32am |
I have a list somewhere, you need the two types of rubber washer for the cam cover bolts as a must.
14th Apr 2017 1:31pm |
Different class mate did a read up on the vanos solenoid part and going to do that with the gaskets. Thanks a lot. |
14th Apr 2017 4:17pm |
Cool, this is the correct sealant to use, good luck
14th Apr 2017 4:39pm |
