Home > Technical (L322) > EGR temperature sensor |
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 |
You know when you think I have just typed something stupid - a temp sensor obviously measure temperature !
17th Apr 2017 8:37pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2301 |
I replaced mine in far less than 5 hours only to have the new one throw the same fault within a few weeks. From other reports it appears that the fault can be ignored. I didn't notice any difference when the new sensor was new. |
17th Apr 2017 9:32pm |
Macca314 Member Since: 12 Feb 2017 Location: Lincolnshire Posts: 23 |
Hi. I have got this issue at the moment, seems it connected to fault code P245A and P040A
12th Jun 2017 9:03am |
mikeyyn Member Since: 17 Oct 2011 Location: Notts Posts: 53 |
Hi, I had a fault with EGR sensor, fault code P0486-17 (27) Exhaust gas recirculation sensor B circuit - General electrical failure - circuit voltage above threshold
22nd Jun 2017 3:23pm |
TOF Member Since: 13 Mar 2013 Location: Gloucestershire Posts: 53 |
What lead you from that error code to a throttle body replacement...? Mine has the same code also.. |
23rd Jun 2017 5:27pm |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
What is the fault code you have exactly?
23rd Jun 2017 6:18pm |
Mine is P040(D)
23rd Jun 2017 6:58pm |
23rd Jun 2017 7:35pm |
TOF:
25th Jun 2017 5:35pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2970 |
That sensor not working will stop the DPF regenerating on the car.
26th Jun 2017 10:01am |
