Home > Technical (L322) > It limped then it died (many times) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2303 |
Find the reason for the fuel gauge playing up and it may well fix the low on fuel condition that is programmed to allow the engine to restart and run for a short distance before cutting fuel again. |
19th Apr 2017 4:00am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
Look for the easy (cheap) fix first - put some fuel in as it sounds similar to what would happen if you ran out.
19th Apr 2017 5:53am |
Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115 |
The fuel gauge started playing up a couple of days ago, knew I only had around 100 miles left so filled it up yesterday. So could this be a self preservation thing that it thinks it actually has no fuel. Not been any distance since the gauge played up but did a ten mile run yesterday when it started happening. |
19th Apr 2017 6:24am |
Yes, it's trying to prevent the high pressure pump from running dry because that would destroy it. The same precautions occur with the 3.0 T/SDV6. |
19th Apr 2017 7:13am |
So lumpy running and cutting out could all be explained by the low fuel warning ? After a search I've noticed that some are ignoring fixing no fuel gauge and running round like that, how ? |
19th Apr 2017 12:56pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7751 |
I know all about it - but in answer to your question it would depend on where the fault lies - if it's a dodgy gauge or cable to the gauge then you could ignore it - if its some sort of sensor that also reports to the fault to an ECU then there may be knock on effects as seems to be the case with yours.
19th Apr 2017 1:21pm |
from rave.
19th Apr 2017 5:04pm |
I'm guessing that's the same for the 4.4 if so thanks that's helpful information and explains a lot. |
19th Apr 2017 5:20pm |
Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174 |
Symptoms similar to my TD6
19th Apr 2017 9:54pm |
So for those interested it's repaired, pretty mush as listed in this post http://www.fullfatrr.com/forum/topic41061-15.html
27th Apr 2017 8:26pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Nice one! Glad it wasn't too serious. Who did the repair for you? Cheers, Greg
27th Apr 2017 8:30pm |
