Home > Technical (L322) > Possible suspension prob |
jambo27 Member Since: 03 Dec 2013 Location: Staffordshire Posts: 124 |
The front bags have shocks inside them which is why its recommened to change them in pairs - well that and sods law says the one you don't change will fail aboit 7 days later. As far as I know the rear are just bags without shocks in them.
23rd Apr 2017 7:23pm |
the rears the shocks are separate "standard" units on the front side of the lower arm. There is nothing that can't be fixed with a hammer😜😜
23rd Apr 2017 7:36pm |
Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174 |
Thank you both for your input.
23rd Apr 2017 7:55pm |
Just remembered that I have replaced then some 60000 miles ago.
23rd Apr 2017 8:04pm |
Nothing visible so just going to replace both rear shox and cross me fingers.
23rd Apr 2017 8:36pm |
****Update****
27th Apr 2017 1:02pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 498 |
I presume you mean the upper hub bush (links the wheel hub to the suspension arm).
27th Apr 2017 1:49pm |
Superb thank you
27th Apr 2017 2:18pm |
Ooops,
27th Apr 2017 3:44pm |
Thank you for the replies and links.
27th Apr 2017 11:36pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Yes, upper and lower bushes are different parts.
28th Apr 2017 5:56am |
Yes thats what I was thinking.
28th Apr 2017 7:15am |
Hi, haven't got my parts list to hand right now, but if you go on advanced factors web site( site sponsor)and look up range rover l322 rear hubs, all the part numbers you require are there, he does post out very quickly, in fact I don't think he's too far from you if you are in Poole.
28th Apr 2017 9:16am |
Both upper and lower bushes (sometimes known as knuckle joints) in themselves are NOT AJUSTABLE, and only differ in size, the lower ones are bigger in diameter and also use a circlip.
28th Apr 2017 1:46pm |
