Home > Maintenance & Mods (L322) > Upper tailgate stops?
stucart
Noticed that the upper tailgate on the near side isn't touching the round castellated rubber buffer, the drivers side is easily screwed in/out but the near side is stuck! Tried to grip it to turn it with pliers, no good , so I tapped it round with a hammer and screwdriver and it turned, unfortunately it's not moved the adjuster it's undone the whole thing which now won't tighten again. Anyone know what's on the back? I darent take it right out in case the back nut falls inside the box section and can't see how to get behind!,,
Here's a pic of it. ( it's appeared in landscape when it should be portrait i.e. View it 90degrees clockwise)
Post #435717 23rd Apr 2017 7:44pm
