Home > Technical (L322) > Need a new spare key - any recommendations?
natalie0301
I have lost my spare key for my L322 and must get around to buying a new one. I have been quoted over £700 by a main dealer Shocked
The key I have is missing the blade too.
Can anyone recommend a less expensive route (other than eBay as I have heard some horror stories).
Thank you!
Post #435833 24th Apr 2017 10:05pm
Try Dan @ Duckworths for the part
You will also need it pairing with the car, but hard to see how that can be more than 15 mins of labour - but I could be wrong.
Post #435835 24th Apr 2017 10:14pm
natalie0301
Thanks for the reply. I'm in Surrey so not sure that Duckworths is an option...
The dealer wanted 2 hours labour Rolling Eyes
Post #435836 24th Apr 2017 10:15pm
rar110
You can pair a key with an IID tool. ______________________________
Post #435841 24th Apr 2017 10:54pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
If you have 2002-2005 I can help with immobilizer chip, casing and remote (it would be an upgrade to flip style) but you would need a blade to copy
Post #435886 25th Apr 2017 7:24pm
HGv driver
Wales
a new key from dealer about 170£ all they need is your vin# no pairing required
Post #435995 26th Apr 2017 3:00pm
Have you tried it & 100% certain ?
When I did that, they were able to cut the physical key from the VIN, but said it still needed pairing......
As the VIN is visible from outside the car, you have to produce the V5 to order a key.
I was also able to get a used key I bought from eBay paired to my car, so I think the key isn't coded to the car - the car is coded to accept the key - but could be entirely wrong.....
Post #435998 26th Apr 2017 4:22pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Couple of months back we had to have a new key for our 2003 L322.
We ordered one from the dealers and I went over one Saturday morning for them to pair it to the car, after 2 hours they came out and said that they couldnt pair it as their was a fault with the new car supplied by LR!!
So another 2 weeks waiting for another key to come, this one worked.
However....
Now the drivers door lock has failed which has been on order from LR for the past two weeks, hopefully the new key that we have will now work with this new door lock......
Post #436018 26th Apr 2017 6:44pm
Lukie
just to help others looking for key's for the older 2002-2005 BMW electrics and keys
there is 2 types of key that can be used
the original "lollypop key" and a later 2005-2010 flip key can be adapted for use with 2002-2005
the keys are made up of 3 components
1'st is the key housing with blade, fixed blade with lolly pop key or flip blade key the key can be copied by a good locksmith, the key will work in the door but do nothing with the ignition
second component is the RF (central locking) circuit this only operates the remote central locking and arms the alarm, this is programmed by yourself, these car be reused second hand just SYNC them to the car (lots of guides about so won't bore you)
the third component is the difficult one, the immobilizer chip, I belive that land rover pre program 6/7 chips from factory, you get 3 instantly, any ordered will be coded to the car's ecu (if you have changed your BCM or EWS ordering a key from the dealer will be useless)
limited members and BMW owners will be able to help with the immobilizer chip, I can help with the chips but I do need the EWS unit here to program
Hope this helps clearing up confusions with the keys
Post #437722 9th May 2017 8:07pm
