Home > Off Topic > Any advice on sound deadening a cupboard? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7752 |
I'm not a complete expert, but did put a lot of effort into this when I extended my house.
26th Apr 2017 9:22am |
That's what I used on mine, silent coat stuff for cars which sticks on to the panels. Also make sure the sump is sitting on some closed cell foam at least 10mm thick. This stops the drone of the lift pump and protein skimmer. You also need a good lid for the sump to stop condensation, either that or ventilate the cabinet with some quiet PC fans.
26th Apr 2017 12:08pm |
Plasterboard, one or two layers as required. |
26th Apr 2017 1:33pm |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 |
Thanks so much guys! It's a new set up and I haven't even isolated where the drone is coming from yet as haven't had time. But the fact if you press hard on certain parts of the oak cabinet it shuts up I'm hopeing I can stop it. Will try find the cause of noise tonight.
26th Apr 2017 1:45pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Yes, or fermacell which you can glue. You can even get acoustic glue and sandwich board together. Where noise is concerned weight is everything. |
30th Apr 2017 8:21am |
If you are using plasterboard, then go for a 15mm sound block board.
30th Apr 2017 8:31am |
Morning all.
30th Apr 2017 8:48am |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
The stuff you want is the sheets used to insulate the engine room on yachts.
30th Apr 2017 9:12am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Can't beat several layers of plasterboard as mentioned above. As many layers as you can fit.
30th Apr 2017 9:14am |
You can beat plasterboard
30th Apr 2017 10:04am |
If there is damp around use the green board, its moisture resist There is nothing that can't be fixed with a hammer😜😜
30th Apr 2017 7:45pm |
Thanks again to everyone!
8th May 2017 7:34pm |
