Home > Maintenance & Mods (L322) > Creaking and squeaking from front off side suspension
smiler289
Hi! Amongst my ffrr's many problems it has started creaking from the front offside. Started when weather got drier. Have sprayed bushings and joints etc on suspension but it still creaks. If the suspension is set to full height it's perfect no noise at all! Is there something I am missing?
Post #436198 28th Apr 2017 8:57am
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
Might be worth looking at the suspension air bags, might be gone dry and creaking against the strut but stops when extended, try spraying them with some silicone lubricant or similar.
Post #436224 28th Apr 2017 12:37pm
Ian928
Norway 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Our L322 sounded like an old iron bed until we changed the lower suspension arms. Apparently it is the ball joint that creates the lovely sounds.
Post #438860 19th May 2017 6:59am
smiler289
Updating thread.
Found to be dry lower ball joint. I think it might be part of the control arm.
Lubed with my grease gun needle and is ok now. I expect arms will need changing in future.
Post #447910 15th Aug 2017 9:57am
