Home > Maintenance & Mods (L322) > Gearbox leak.....specialist needed in London |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1340 |
I can't help with a recommendation I'm afraid, but would advise against driving the car too much before it's sorted, my current car had a gearbox oil leak while under warranty and the LR response was to fit a new gearbox, even though it seemed to be running fine, with no noise or other symptoms. I had lost a surprising amount of oil in a short time, without too much being visible on the ground, the plastic tray under the front of the engine seems to retain some and some will be flung off as one drives along. Only Range Rovers since 1988 |
28th Apr 2017 7:24pm |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
The only place I can recommend from personal experience is Hardy Engineering in Leatherhead.
28th Apr 2017 7:55pm |
