Home > In Car Electronics (L322) > No sound from speakers etc |
rattly Member Since: 15 Oct 2016 Location: Cotswolds Posts: 32 |
Hi all,
29th Apr 2017 3:57pm |
Hi,
30th Apr 2017 9:36am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7605 |
The DSP is the black box nearer the rear light.... 2011 Range Rover Vogue SE 4.4 TDV8
30th Apr 2017 10:40am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Turn the ignition to position 1 (AUX) and look at what's listed of the screen , with the radio off!, in the list you should have DSP... From memory it's on the left hand side 3 row... If it isn't there then it's gone pop again
1st May 2017 11:59pm |
Brilliant, I`ll have a look.. sods law its working today, but at least I know what to look for later.. Cheers, rattly |
2nd May 2017 12:05pm |
Sharky1168 Member Since: 21 Jul 2015 Location: Rochdale Posts: 23 |
Mine isn't the DSP just the HSE (standard?) Lear Amplifier which decided not to work. After searching for a replacement, which are quite pricey even on eBay, I found a guy who repairs them & whilst £80 isn't as cheap as doing the repair yourself, but with my soldering skills, well worth the extra! Current RR L322 TDV8 VOGUE
5th May 2017 8:59pm |
Hi,
5th May 2017 11:10pm |
Typical 'ang' 'over ... now that your on to the fault it'll go away... It'll be thinking up a new wheeze to worry you with Yesterday I couldn't spell Engineer... Today I are one!
6th May 2017 10:17am |
Funny you should say!!!.. radio hasn`t played up since, but display has gone now!. is it the same unit playing up??
28th May 2017 12:53pm |
