Home > Maintenance & Mods (L322) > Jack which can lift the full fat wheel off the ground |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
do you think a td5 disco bottle jack would do ? |
10th May 2017 5:42pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
I am using one with a piece of 4"X6" under for added height |
10th May 2017 7:20pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
you've obviously never jacked up a ffrr....cos they go on and on and on... and just when you think it'll never lift the wheel off the ground it finally does.. And for all you ffrr jacking virgins take our word for it rather than put it to the test... jacking up a ffrr with either a 2 stage bottle jack or the factory jack is not something that should be done for fun, only in an emergency, and as a last resort Yesterday I couldn't spell Engineer... Today I are one!
11th May 2017 8:22am |
naks Member Since: 28 Sep 2016 Location: Stellenbosch Posts: 26 |
even if you jack it up under the suspension arm?
11th May 2017 9:15am |
That's not the safest option, it only takes the suspension to have one of it's little paddies and it'll pop off the jack.... if you use a high lift (2 stage ) bottle jack in the jacking positions on the sill it is held in place... I'd only use my trolley jack to raise a ffrr at that point cos the cup is 100mm dia and it also has a rubber insert for added grip Yesterday I couldn't spell Engineer... Today I are one!
11th May 2017 9:04pm |
perfect will put in car. have only jacked up car with trolley jack about 100 times at least. don't want caught out although I am with the AA I never needed them for flat (yet) especially with lpg so room for spare is not possible . |
12th May 2017 4:31pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Ebay seller would not accept £30 offer, almost instant decline, did accept £33.
12th May 2017 7:39pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
dispense with blocks of wood, spacer etc and just get this and have plenty of lift.
16th May 2017 10:48am |
Les_Paul Member Since: 14 Jun 2017 Location: Houston, TX Posts: 9 |
How about this jack? Just keeping it in the truck won't harm the longevity of the jack?
17th Jun 2017 5:10pm |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 252 |
@nino.
17th Jun 2017 6:43pm |
NOPE!! it's a single stage lift, the Mercedes Sprinter jacks are telescopic 2 stage, which gives them almost twice the lift of a standard bottle jack. Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
18th Jun 2017 10:14am |
Gyre8,
18th Jun 2017 4:52pm |
Ah. Thanks, Nino. |
18th Jun 2017 6:33pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Any reason why lifting from the suspension arm is not recommended?
18th Jun 2017 7:05pm |
