Home > Technical (L405) > Stealth mode
AMTony
Stealth mode
Does anyone know what this does or is yet another useless feature?
Have tried on and off and I cant see any difference at all - bit like sports mode Laughing
Post #437985 11th May 2017 1:41pm
Caddyshack
United Kingdom 2014 Range Rover Autobiography SDV8 Indus Silver
I believe it dims the "mood lighting" so it doesn't look like you are sitting in the car with the lights on...
It certainly didn't work hiding outside the student nurses accommodation at night...they spotted me straight away and called the Fedz Big Cry
Post #437988 11th May 2017 2:12pm
AMTony
Car is fairly dark inside at night so only conclusion must be that mine doesn't work?
All the mood lighting is on but is fairly subtle in terms of overall in car brightness, certainly stealth mode doesn't seem to have any noticeable difference.
Post #437997 11th May 2017 2:29pm
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
On my car the Stealth is activated when you turn off the main screen. At that point the speedometer graphics go to the 'torchlight' mode, the temperature readouts turn off and mood lighting is turned off.
If you enable or disable the stealth mode in the menus then unless it is dark and you turn off the display you will not see any difference.
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #438001 11th May 2017 2:39pm
AMTony
Thanks Nick - read something about this but how do you turn the screen off?
Post #438003 11th May 2017 2:49pm
Nick Ground
Depending on your spec, there is a power 'hard' button on the bottom left side next to the screen, or it is a 'soft' button om the bottom left of the touchscreen home screen.
55 D3 SE
98 MX5 1.8 RS
Post #438005 11th May 2017 2:51pm
AMTony
Thanks - will press and see what happens Thumbs Up
Post #438007 11th May 2017 2:55pm
bear100
Yep, you enable stealth, then read the instructions on the screen! Press the off button on the bottom left corner of screen Thumbs Up Thumbs Up 2010 defender utility
2010 RRS TDV8 (gone)
2007 discovery 3 (gone)
2004 discovery 4 (gone)
1994 discovery 1
1970 v8 hybrid (gone)
1975 bobtail (gone)
Post #438075 11th May 2017 10:08pm
AMTony
Thanks everyone - never realised there was the image of an on/off button on the screen.
It is quite hard to see the feint image all that way away....best put the old glasses on in future Rolling with laughter
I now have srealth mode which should be renamed 'mood lighting off'
Post #438099 12th May 2017 7:07am
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
what do people think of the overall intensity of the mood lighting, I have mine turned up fully but unless there is something like a cleaning rag in the door cubby reflecting the lights then I can hardly tell its on. this may of course be something I am not doing correctly. :-} Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #438116 12th May 2017 10:11am
w8pmc
United Kingdom 2016 Range Rover Autobiography TDV6 Carpathian Grey
Mine's set to blue & i'd say they're quite bright & certainly unmissable. Obviously in the daylight they're not as easy to see, but in the dark they're very obvious. Paul
MY17 TDV6 Autobiography In Carpathian Grey With Cirrus Interior
Post #438382 14th May 2017 8:01pm
Lutonboy
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
I've set mine to orange/yellow and its fairly unassuming even at full brightness. I like it though, fits well with the Almond/Espresso.
Post #438592 16th May 2017 2:52pm
