Home > Maintenance & Mods (L322) > Fuel gauge not reading correctly
smiler289
Hi
My fuel gauge is not reading correctly. If I fill the tank right up it only goes just passed 3/4's on the gauge and when I turn the car off the needle sits on the side of the gauge. Do you think this could be a problem with the gauge needle rather than tank level senders? I did the self test and took these screenshots from the video I took:
Post #437986 11th May 2017 1:51pm
rar110
There's a few posts on this issue. It's probably the in tank wiring issue that seems to occur with age. ______________________________
Post #438070 11th May 2017 9:32pm
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
I had a very similar problem with mine after a fuel pump replacement.
Whilst fitting the pump the float came loose from the pump body and ended up floating in the tank,
With a full tank the gauge on the dash read just over 3/4 and that's because there's a float on the left hand side of the tank that was feeding the gauge while the pump float was broken.
Post #438078 11th May 2017 10:18pm
