Home > Technical (L322) > Central locking not working |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 |
I dont know if this is connected to my interior light post, but after a problem with the battery discharging yesterday I cant get the central locking to work on either the remote or manually. I have tried the battery re-set and the turn ignition on/off press unlock then lock three times whilst holing the unlock button on the remote (has worked before) but there is no response from the central locking and the red led on the remote flashes 10 times - is this a code? Could this be connected to the interior light problem? QUID FACIUM TIBI
11th May 2017 8:31pm |
Thought about the fuses for this and the interior light problem - the thing is the handbook lists the fuse as also controlling the windows and they are working. I will have a look tomorrow and keep my fingers crossed.... QUID FACIUM TIBI
11th May 2017 10:22pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3055 |
Bcu controls this function and may need replacing - it's under the passenger seat. |
11th May 2017 11:32pm |
Deltaevo Member Since: 02 Apr 2017 Location: Ashbourne Posts: 39 |
Unnecessary quote removed
13th May 2017 9:07am |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
she mabe in transport mode central locking not working interior lights not working if you had to jump start you could have spiked the ecu you will need a reset which can only be done with correct software . had same prob with mine after jump start tried everything but it was a simple fix . hope its the same for you |
13th May 2017 9:47am |
Checked all the relevant fuses today and all are ok. The central locking/alarm set works with the key but not with the remotes even after the correct re-sync procedure. None of the courtesy lights are working, that is the rear tailgate/rear passenger(can be turned on manually)/front passenger(cant be turned on at all)/puddle/door mirror & glovebox lights. The map lights do work and the glovebox light worked for a while after I removed/replaced one of the central locking fuses accompanied by a whirring noise from the centre console, but then it went off. Would a vehicle electrician be likely to have the correct software or am I likely to need to go to a JLR main dealer? QUID FACIUM TIBI
13th May 2017 7:17pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Are your front wipers working? Sounds like it's partially in transportation mode. Failed or failing bcu? |
13th May 2017 8:30pm |
As far as I can tell, everything apart from the courtesy lights and the central locking works. QUID FACIUM TIBI
13th May 2017 11:11pm |
definitely transport mode you will need a reset don't pull fuses and waste your time this happened to me and I was standing on my head trying to resolve easy fix |
14th May 2017 11:06am |
you will need main dealer or someone with correct diagnostic tool normal software will not reset this as I had auto electrician working on mine for over an hour . went to auto tec Greenock and 5mins later she was back up and running £50 out of the wallet give them a call and they will advise what software required mechanic using laptop told me his software cost £70.000 |
14th May 2017 11:12am |
Job done. Went to a local sparkie with the correct software and he sorted it in five mins. £45 well spent (by which I mean it gets SWMBO off my back). QUID FACIUM TIBI
20th May 2017 9:46pm |
Glad you got it sorted |
20th May 2017 11:17pm |
