Home > Maintenance & Mods (L322) > Reduced Engine Performance...again... |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
Check the aux coolant pump is wired the correct way round (loads of posts online about the LR Technical Service Bulletin) - Many of them were wired incorrectly at build
15th May 2017 8:52am |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
As above.
15th May 2017 9:09am |
Knightmare Member Since: 22 Jun 2015 Location: Kent Posts: 84 |
Thanks guys, very helpful.
15th May 2017 9:49am |
unsolicited Member Since: 30 May 2016 Location: London Posts: 122 |
Yup, supercharger pump vastly likely. If you have an IID tool you can confirm almost immediately. |
15th May 2017 6:44pm |
Thanks all, spot on...aux coolant pump was indeed wired incorrectly. Life is what happens while you�re making other plans. |
19th May 2017 9:29am |
19th May 2017 9:31am |
Swapped pump for a new one. So far so good. Life is what happens while you�re making other plans. |
19th May 2017 4:01pm |
