Home > Technical (L322) > Any info on changing a TDV8 3.6L Power steering pump? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1688 |
Done from above. Bit awkward and fiddly, as everything is on these cars
21st May 2017 12:45pm |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 137 |
Thanks Mikey. So no need to go underneath at all? How long did it take you? I've got the fan and belt off already. Rehab is for quitters!!!
21st May 2017 12:51pm |
It took somewhere between 2-3 hours, but that was my first one |
21st May 2017 1:08pm |
Thanks again. This one drove in and when the owner went to leave there was a puddle underneath and steering was groaning. The reservoir was low and the oil looked blackish. With the belt off the pump has a little movement not the pulley and sometimes clicks when turned by hand. I can't actually see the leak so am guessing it's the pump. Does this sound about right? Btw it appears the oil is only available from LR although I see Island 4X 4 have an alternative at £11/litre rather than £19/litre. Anyone any experience or thoughts on the oil?
21st May 2017 1:17pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
The leak is more likely to be at the rack end on driver side. ______________________________
21st May 2017 9:25pm |
