Home > Technical (L322) > Broken drivers door mechanism? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7605 |
My Indy did mine on my TD6..... I understand if you get it wrong, you can't open the door from outside or inside..... 2011 Range Rover Vogue SE 4.4 TDV8
21st May 2017 7:43pm |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
I had same prob. fitted aftermarket cable no probs so far . its a pretty simple fix just a bit fiddely getting interior handle coupled up but after a few attempts you will be expert . give everthing a good oil when you are in there . good luck |
21st May 2017 7:49pm |
There are some videos on YouTube... this is one of a few. Might be one of a number for the complete job.
21st May 2017 8:06pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6397 |
^^^ 0/10 for camera work .
21st May 2017 9:41pm |
RRR207 Member Since: 27 May 2016 Location: Basel Posts: 49 |
Cheers
22nd May 2017 7:28pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3035 |
@RRV207
17th Jun 2017 9:07am |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
Dolphinboy it's quite a simple job, took me about 15 minutes in total.
17th Jun 2017 11:08am |
I used Downfield Garage, Downfield Rd, Clifton .... 0117 9737355
17th Jun 2017 11:14am |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 |
I have the broken cable problem too.
17th Jun 2017 11:11pm |
Yes but doesn't need to be as long, negative first. Ed |
18th Jun 2017 7:49am |
