Home > Technical (L322) > TD6 Gearbox filler size
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
As above really gents, anyone know off hand the size of the Torx bit for the gearbox filler plug (I'm assuming it's a torx). Got a few broken ones that I never bothered to replace so want to make sure I have the correct one before putting it on the ramp.
Thanks
Post #439471 24th May 2017 6:56pm
The filler plug requires a spanner (15 or 17mm) - makes sure this comes off before tackling the drain plug, six sided ring spanner best for this if tight, not enough room for a socket.
The drain plug is a torx, something like a 45 .
Post #439493 24th May 2017 9:29pm
rodp
Thanks Thumbs Up Got plenty single hex spanners, it's big torx that I'm short of. Should replace them when broken, but you never do until needed Embarassed I'll have a look around for some good torx, doubt if I'll invest in snap on anymore though at my time of life.
Post #439495 24th May 2017 10:13pm
