Home > Technical (L322) > Transmission cooler thermostat |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 |
I'm confused on the Transmission thermostat function. I'm assuming it redirects coolant to the transmission cooler but wasn't sure at what temp it is triggered to open. Anyone have a clue? |
25th May 2017 7:30pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 911 |
According to RAVE the thermostatic valve is opened by transmission fluid temperature. When this reaches 80°C the valve opens to allow engine coolant through the cooler.
25th May 2017 11:05pm |
Thanks Phil. Apparently I missed it. So theoretically the engine thermostat mod doesn't affect the cooling of the transmission fluid. |
28th May 2017 2:02am |
Once above 80°C the transmission fluid will follow the engine coolant temperature. At light loads the electrically heated thermostat will allow the engine coolant to climb to over 110°C. I frequently measured transmission fluid temperatures above 100°C during normal steady-state conditions as a result of this.
28th May 2017 11:44pm |
Great! I was needing to add about 8oz of coolant every 600 miles. Just got back from the same trip at about 700 miles and no measurable coolant loss through the radiator pinhole. The pinhole itself is almost dry. I have to believe that the theory of less stress to the cooling system is more than theory. Theory tested so now I can fix the pinhole. |
30th May 2017 2:02am |
